Loco Honkey
Banned
In the ten Hondas I've lowered, ranging from Civics to Accords to Preludes to Integras, and between the stock 13's on the Civic to 18's on the Accord, anything less than 2.5" will NOT need a camber kit if you get an alignment immediately after you lower it. Tire wear will NOT be affected to the point of cording the tires in two months. If you need to adjust your camber, just slot the holes that the UCA bolts go through, rather than spend $250 on a kit. I've done this on ITA FC RX7s, and in five seasons since, there haven't been any problems.
