That diagram is an EXAMPLE only. It may or may not be the same as what you are looking for.ok so i looked into the wiring from that link you sent me dual. i noticed that at A15 it looks like i should splice into it. i cut itand soldered a wire to resistor box. from the diagram it appears wrong... any idea?
You need to pull the correct wiring diagram from the year and model of the engine donor vehicle and ensure the ECU & distributor are compatible with it.
Sorry if my link led you astray.
