i'm f-cked (head stud)
Discussion in 'Civic and del Sol - EG and EK' started by custompainter, Apr 28, 2007.
  1. custompainter
    custompainter drive it like U stole it
    central CT
    ok so i blew my head gasket no biggy i can replace it well took everything apart do everything by the book put everything back together and then i start putting the head bolt back in LOL what a joke on me i thightened this bolt by hand with my fingers right it gets suck half way in so i take my wrentch to it turns a little and stops so i try to back it out the damn thing wont move so i'm sitting here with my car in the garage wondering should i try to tighten it and chance break the bolt or try to take it out and break the bolt LOL cause the damn thing wont turn either way
    can you tell i'm pissed !!!!!!!!!!!!!
  2. custompainter
    central CT
    well i got some good news fixed the problem i ended up snapping the head stud lol gotta love it anyways i shot up to my job and used some machining bits of my bosses and drillout the bolt retapped it and i'm all good i still dont have a clue as to why that bolt locked up the way it did
  3. dtob
    dtob New Member
    Could be hydrolock. Was there oil in the threads or in the bottom of the hole?
  4. supwhoaday
    supwhoaday New Member
    i have the same problem when changing out intermediate shafts! you can unbolt it but you mess up the threads when bolting it back on! i even have to shim the bolts cause it wont bolt all the way in. when you find an answer to the problem let me know! lol
  5. custompainter
    central CT
    well i never really did find out the problem i got my car back together and drove it around all day and no problems
    i did ask a friend of mine he told me it was cause i didn't loob the studs before i put them back in
    but i dont know i never had a bolt lock up with just the turn of my fingers like that before - and i know my fingers arn't that strong ~ or maybe they are look out ladies super fingers is in the house LOL........... i'm changin my screen name LMAO................
    anyway i really dont know what caused it to happen
  6. MoSeS
    MoSeS New Member
    you are not supposed to reuse head bolts. after they are installed they stretch, since they stretch they are no longer the right size and you are supposed to use new ones. ARP studs dont do this and they are reuseable.
  7. dtob
    dtob New Member
    Ummm... isn't that the stock head "bolts" your not supposed to re-use? The reason why people get these head "studs" is for the fact that you can re-use them. Well and they are stronger too.
  8. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    he's right... ARP are the only studs i know of that don't stretch... but studs usually don't stretch out that much. my guess is that you go it cross threaded or didn't use anti-seize.
  9. MoSeS
    MoSeS New Member
    if you read his first post its says he is using head "bolts" not studs, i just put the wrong word in there
  10. custompainter
    central CT
    sorry for the confusion they are stock head bolts and you can re-use them i work for an engineer who designs heads - he's even got a patent on one (if you got time check this out - Anhared Design ) i got a job working for this guy couple months ago not know anything about his other bussiness turns out my boss is quite the engine man ~ i'll take his advise over any
    that link is for the website this is the engine i was referring too Anhared Design - Project Management
