Bobby17772
I was doing some research on injectors for when I decide to boost my car. I was messing around with the RC injector chart and I was messing around with some numbers, like if I was to get bigger injectors or stay stock or use an FMU (I know I know I've read up on them) and it seems like if I was to go for a tune for 200 crank hp I would need like 388cc injectors...so like 390's or whatever or even 450's.
But when I put the numbers in for using a 10:1 FMU at 6 psi that would bring the rail pressure to ~105psi and it says I would only need 254cc injectors (or pretty much stock honda injectors)
can anyone tell me if this is true? if so how?
thanks for the help
thanks for the help
