Integra jdm type r coversion help!!!
Discussion in 'Integra' started by 01GSR, Feb 5, 2007.
  1. 01GSR
    01GSR ALL SHOW SOME GO!!
    Des Moines
    need help swaping my usdm to a jdm coversion need help in what need to do to complete the swap properly like welding,extra parts, radiator ,ect. im clueless
  2. Reckone
    Reckone EF aholic
    Albany, NY
    The front radiator support needs to be cut off and replaced with a itr one which needs to be welded in. Everything else pretty much is a bolt on process.
  3. 01GSR
    Des Moines
    thanks thats really helpful. So can i use the itr radiator and fan to replace mine in my gsr do you know if that will fit
  4. 801CRX
    801CRX Got Rice?
    UTAH
    I dont see why they wouldnt
    They were made for the support your putting in.
  5. onesikdb8
    onesikdb8 Member
    AZ
    the GSR radiator will also work
  6. 01GSR
    Des Moines
    thanks for the advise. so is that your shop #, can they help me on some conversion questions. thanks
  7. onesikdb8
    onesikdb8 Member
    AZ
    Sure...you can call us. A lot of times it is easier to reach us via email due to the high volume of calls that we receive each day, we are not able to answer every single phone call.
    Email me at steve@tokyospeedpros.com with your specific questions and I'll help you.
