integra ls 94
Discussion in 'Integra' started by ez7, Apr 18, 2008.
  1. ez7
    ez7 New Member
    i got a question would it be better to do my integra ls 94 into ls/vtec/turbo or ls/turbo
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    ls/turbo
  3. BrutalB83
    Rochester Hills, MI
    How much power do you want to make and how much money do you have to spend?
  4. ez7
    ez7 New Member
    i dont want to spend much but i want to get the most power i can what would it be the difference between ls/turbo and ls/vtec/turbo
  5. AHHVTEC
    Alabama
    spending the extra money to make it vtec then turbo is just a waste
  6. ez7
    ez7 New Member
    well i got the turbo but dont know if i should go vtec or invest in other things
  7. BrutalB83
    Rochester Hills, MI
    VTEC heads flow better than non-VTEC ones, so you will see a performance increase. It's up to you whether it's worth it or not. Keep in mind that you'd probably want a better transmission and you'll definitely need a VTEC ECU as well...
  8. AHHVTEC
    Alabama
    if it where me id rather spend the extra money making the non vtec head flow better
  9. BrutalB83
    Rochester Hills, MI
    :werd:
    Port n' polish on the LS head, some turbo cams and you'll be good to go...
  10. 90DATeggy
    90DATeggy The Pussi Snatcher
    FL
    Ls/turbo Pnp Heads And Ur Good +2 On That Brutal
