Integra suspension on CRX
Discussion in 'HYBRID -> ED-EF / DA' started by tigerr227, Feb 9, 2008.
  1. tigerr227
    tigerr227 SEE-R-X
    carolinas
    what do i need to do to convert my CRX suspension to integra the setup is from my 94 integra to a 90 CRX SI?
    Thanx for all positive replys
  2. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    I think that'll make your rex sit too high. I'd just buy a set of Tein coilovers or better.
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    you need the integra suspension...for the rear you need the trailing arms,lower control arms,hubs,ebrake cable,and all that stuff...
    for the front you needs,the springs,struts,lower control arms upper a-arm and hubs..just take the front off as one whole assembly per side itll save time and work
  4. 99sidude
    Ohio
    This won't work without serious modification! The dc2 integra suspension bolts onto a 92-95 civic. It won't work with anything older.
  5. BrutalB83
    Rochester Hills, MI
    Maybe's he wanting to do the 90-93 suspension? Either way, I think it's a waste of time. Unless you've got a full donor car to pick parts off of, you might as well just buy after-market stuff for the CR-X.
  6. 93civicracer
    Texas
    Just shell out around $1,000 for quality adjustable coilovers and if you're lowering the car get a camber kit for each side while you're at it should run about an extra $100-150.
  7. 99sidude
    Ohio
    Well DA brakes would be a good upgrade from the ear drums on the crx. Other than that, its a waste.
  8. KillerX
    KillerX Junior Member
    get a 90-91 civic EX an swap the front brakes .use the front knuckles with the calipers you end up with larger dia. rotors its the best set up for the money .its killer braking just with that set up.
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    edit!!!i looked over the fact your trying to use suspension from a 94...it wont work w/ out modding,,
    just get the rear disk brake assembly from a 90 integra and call it a day
  10. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    What exactly are you trying to swap over?
    The shocks will swap over(may ride a little higher; will have to use the Integra shock forks also; and the 88's have the same style rears as the ITR). The +94 rear brakes will swap over too; just use the stock LCAs, links and Si ebrake cable..
  11. eg6sir
    or find a rear disc from a 91 SI or 92-93 GSR
  12. tigerr227
    tigerr227 SEE-R-X
    carolinas
    Sorry all, even though its accurate i wasnt as specific about what im doind. I said suspension which is true but mainly and or also the 4 lug hub assembly, I found a site that sells a stock 5 lug set up for an 94 ls integra and yes i have a complete donor car with all the stuff i was wondering what i would have to do to get the integra hubs and all to fit. I also have lowering springs on the integra,would i be able to use just the springs for the 90 CRX Si or is there modding to do. And again the site sells the 5 lug hub to fit the integera ls hub assembly Naturaly no mods. So what i was hoping is to just buy the hubs put it on the 94 setup and then that setup on the rex and have 5 lugs for dirt cheap, then doing a type r convert.
    Thanx also for the positve responses
  13. K2e2vin
    Raleigh, NC
    Integra's front won't fit correctly. Some guy did that to his CRX and had to lower the car over 4" just to get zero camber. Definitely not practical.
    You can try to get some custom hubs and press those into your stock knuckles, or have those hubs turned down by a machine shop.
  14. 93civicracer
    Texas
    I thought it was a good idea to have a little negative camber?
  15. K2e2vin
    Raleigh, NC
    +94 Integra front knuckles on EF=positive camber. He had to slam it to get zero.
  16. tigerr227
    tigerr227 SEE-R-X
    carolinas
    i need the hub assembly from my 94 integ to fit the rex , theres a site that sells the stock 4 lug assembly for an ls integra in a 5 lug i wanted to convert without alot of crazy searchin and bying so how can i get the integra hub assembly to fit the rex so i can have the lugs, or will it just fit which i know cant be that easy.
  17. K2e2vin
    Raleigh, NC
    Doesn't fit. The shafts are different widths. Only way to make it fit is narrowing down the 5-lug hub shaft with a lathe(may make it weaker), and using custom 5-lug rotors or convert to a ITR brake system(using 90-91 EX knuckles; with the stock knuckles you'd need to use an adapter to move the caliper out).
  18. 90DAB20
    90DAB20 New Member
    What's the address of the site you found the 5 lug conversion on?
  19. LightWeightChamp
    LightWeightChamp Honda FTW!
    MN
    the teg upper A arms will rub on the inner fenders of the rex, just buy the suspension, koni+groundcontrol, ksport, tien, etc.... you will be more pleased with those results
  20. 92civicb18b1
    92civicb18b1 The Trisexual
    old thread guys....
    not too old, but old enough where you'll only get a response like mine.
