Itr Tranny Oil?
Jroc2005
Where do i fill up the tranny oil at for an Itr motor because of 5th gear slippage? and what type should i use?
Thanks for any help ! :unsure:
use a 3/4" drive wrech to take out the fill plug.. located on the pass. side of the car to the right of the differential...
i use the same oil in my trans that i do in my engine
Or take out the VSS (speed sensor) and put it in at the top of the tranny where you can get to it, you'll still want to take the fill plug out to know when it's full, then put just a little more in for good measure after putting the fill plug back in.
