jdm b18c into a 95 civic cx need wiring help.
Discussion in 'HYBRID -> EG-EK / DC' started by Eg6nRpS13, Sep 2, 2005.
  1. Eg6nRpS13
    Eg6nRpS13 Junior Member
    Hello everyone, I recently bought a jdm gsr b18c obd-1. I am planning to put this in my 95 honda civic cx and I need some wiring help. I am at work currently and I can find the answer to this question by looking myself but im here and not home. Is my civic a 4 wire oxgen sensor or a 1 wire? if its a one wire can somebody tell me where to run the wires to the ecu the pinouts. Second I know i have to run and check these wires.
    B18C1/P72 and h22/p13: 7 wires
    Engine ECU Side
    Part Wires Pin-out
    VTEC Solenoid Yellow/Green A4
    VTEC Oil Pressure Sensor Blue D6
    VTEC Ground Black Chassis Ground
    Knock Sensor Red/Blue D3
    Evap Purge Power Yellow/Black 12V Power
    Evap Purge Solenoid Red A20
    Secondary Intake Solenoid (IAB) Pink/Blue A17
    the knock sensor and the iab from what i hear is located on the intake manifold somewhere. I was wondering if I can just tap into them from the main engine harness instead of wires hangin off where its actually at. Can I do the same for the vtec wires to? and the evap purge wires what do i do with those? and also i heard something that i had to wire the butterfly valve wires or some sort consisting 2 more wires. anyhelp would do as I want to complete this project.
  2. Eg6nRpS13
    any help to any of these question will help.
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
  4. Eg6nRpS13
    man you dont know how much easier you made my life man. I was bustin my ass all day to look for something like this. Thanks man ur a life saver.
