Jdm B18c Swap Problems
Discussion in 'Civic and del Sol - EG and EK' started by jordan41906, Apr 15, 2008.
  1. jordan41906
    jordan41906 New Member
    I just put a jdm b18c into my 95 civic ej1 this weekend had problems with the wiring harness b/c some idiot decided to splice one entire end. Anyway the ends are backwards from the stock motor the plugs connect on opposite sides of the engine bay, can anyone tell me how to fix. Also the rear engine bracket I recieved is about an inch to short from reaching the rear engine mount. If anyone could help with these problems I would be very grateful.
  2. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    What car is this going into, and what obd is the engine?
  3. OKCZombie
    OKCZombie Banned
    it's in a 95 civic ex from the sounds of it - I'd bet he has an obd2 motor
  4. BrutalB83
    Rochester Hills, MI
    Are you talking about the harness that's on the B18C, or the harness that came with your stock D-series. If you're talking the B18C harness, then I'm not really surprised. Japanese harnesses are backwards from USDM harnesses. You'd be better off using your stock harness and adding stuff in/extending things where you need it...
