JDM D15b vtec Swap Questions
Discussion in 'HYBRID -> EG-EK / DC' started by HatchHead92, Mar 13, 2008.
  1. HatchHead92
    HatchHead92 New Member
    831 Watson CA
    i got a 92 civic vx with 206,xxx miles on engine. i want to swap the jdm d15b vtec. this is going to be my first swap ,besides a clutch job i did, and i have some questions. i do not know if i could reuse the same tranny , if i should buy some gaskets, the deal with the harness do i have to cut anything and the o2 sensor because mine has 5 wires. My main problem would have to be with the harness scince i heard it is a JDM harness what is the difference? Any help with this swap will be greatly appreciated:D
  2. daveholiday
    daveholiday Do work
    Pittsburgh, Pennsylvania
    In japan, everything is RHD, so the harness is backwards from the USDM ones.
  3. HatchHead92
    831 Watson CA
    i meant i want to swap the jdm d15b vtec into my vx and take out the d15z1 i want to know if i can use my vw harness or any other modifications
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yes use your stock harness
  5. HatchHead92
    831 Watson CA
    reuse my vx harness is what i meant any answers will be of much help Thanks
  6. HatchHead92
    831 Watson CA
    is there any other modifications i would have to do
  7. AHHVTEC
    Alabama
    well i dont think so because both motors are obd1 and vtec
  8. HatchHead92
    831 Watson CA
    will my five wire o2 sensor work ok with the engine just wondering
  9. AHHVTEC
    Alabama
    no your gona have to change that to a 1 wire, if you use the po8 ecu, if you use the p28 you need a 4 wire
  10. HatchHead92
    831 Watson CA
    i am getting the p08 will i have to cut any wires from my harness. i got a teacher over my shoulder so i got to log out:mad: for a while thanks
  11. AHHVTEC
    Alabama
    no just finda the signal wire and splice into it, you will need a 1 wire o2 sensor
  12. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    Or you could just do like I did and since you're reusing your stock harness which has stock 5-wire plug and sensor, just do that and the p08 will only read the 1 wire. Mine was a 4-wire I just plugged it up like that and it worked.
    But I recently got an ebay header and put it on and the 4-wire o2 just wouldn't come off it was stripped to shit so I used the 1-wire that came with my swap and spliced the wire in.
  13. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    :werd:
    I'm using a P05 in my D15B right now(P28 took a shit), and the LC-1 WBO2 is hooked up the same way but it just reads from the single signal wire.
