JDM p30 discussion
Discussion in 'ECU's, Electronics, and Tuning' started by eg6sir, Feb 22, 2007.
  1. eg6sir
    no its from the Civic SiR2 in japan.. you're thinking of the one that goes for twice that price.. the USDM version.. and yes its obd1
  2. nightrider45
    nightrider45 Junior Member
    no i'm talkin about the JDM not the usdm version, I have a p30 ecu it came with my b16a Gen2 (sir-2)swap. And i dont think there is a usdm p30ecu.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well what did the del sol dohc b16 have then
  4. nightrider45
    a p30 ecu obd1, comes with the 170hp with the redline of 8200. The p30 only came with the b16a Sir2 engine which one of the cars where the 92-95 delsol dohc vtec.
  5. AHHVTEC
    Alabama
    the usdm dohc del sol just had 160hp
  6. nightrider45
    i know and the jdm 170
  7. AHHVTEC
    Alabama
    right so what ecu did the usdm b16 del sol have
  8. nightrider45
    didnt the usdm b16 del sol have the p28 ecu
  9. AHHVTEC
    Alabama
    no the p28 is a single cam ecu
  10. nightrider45
    yea i thought so too for the Ex, so your sayin the usdm dohc delsol has a p30 version?
  11. nightrider45
    so they share the same ecu?
    so the p30 came in the jdm 92-95 dohc delsol and wut else?
  12. AHHVTEC
    Alabama
    yea i think so.........bump on a good price
  13. colombian_jam
    colombian_jam New Member
    miami
    so if i use a P28 in my b16a2 im using the wrong ECU or what now im confuse
  14. nightrider45
    i believe it has to be chipped or just rewired with diff. pinout
    dont quote me on that, cuz i've seen b16 with p28 ecu's and they run fine.
  15. eg6sir
    then what ecu is running my car then.. there is a USDM p30.. it came out of the 94-95 Del Sol VTEC..
  16. nightrider45
    if it redlines at 8200 (with stock parts) it's a jdm p30ecu.
  17. eg6sir
    dude, seriously.. i know what i have.. hahaha.. you are so sure of yourself arent you.. anyways.. lets quite cloudin up his thread w/ nonsense .. everyone here but you knows there is a USDM p30
  18. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    What???? My friend runs a P28 on his LS/VTEC with a B16 head??? I don't know ECU's very well so I may be wrong, but are you sure???
  19. eg6sir
    you can chip a p28 or any ecu to run any motor pretty much.. and i never started this thread.. :shrug:
  20. Bruno D.
    Bruno D. New Member
    the p28 is alot better i have both an to chip jdm p30 small box you also have to delete the t/c its a bunch crap p28 chipped is easiest cheapest.:driver2:
