Hi All,
I just wanted to know what you guys think this could be.
I changed the head gasket and the oil is no longer leaking.
Now as the car idle's just fine and drives ok but I keep hearing
a popping noise ( like balloons popping ) I have no idea what this could
be but after just double-checking everything all over again. I began pulling
spark plug wires 1,2, & 3 were all dry but the 4th position was wet with oil.
see picture below for what i mean.
http://www.we-todd-did-racing.com/wetoddim...DEzZGZkMzF5NTQx
Could it be because this sensor is broken.
I think it is the middle hose above the PCV valve
that connects to this sensor. I did extend the wires correctly
to the sensor. If someone can give me the name of this sensor so that
I can replace it that would be great or even sell me one we be perfect. Below
is a picture of the sensor.
Thanks in advance
Thanks in advance
