just finished my swap and i got sum ?? b18a1
Discussion in 'HYBRID -> ED-EF / DA' started by mattyoung2002, Aug 7, 2011.
  1. mattyoung2002
    mattyoung2002 New Member
    i just finished my b18a1 swap in my 90 civic si hatch and i had it running just fine and then it jus cutout and died and it dont even turn over now any ideas
  2. Dagnasty EF
    Dagnasty EF New Member
    Kenosha, WI
    A plug not connected all the way. Maybe distributor or even ecu. Seems silly but they small stuff usually os the culprit.
  3. mattyoung2002
    well i went over every wire and plug i was actuley able to get it to turn over one time without the dist. pluged in and now it wont do nothing at all. i know when u turn the key to the on position the distributer starts to hum and its a new dist.
  4. Dj211855
    Dj211855 New Member
    what? distributor hum..................hmmmm... you mean fuel pump.
    check your grounds, hondas has three grounds. Most important the one on the thermostart housing.
