LCD plus WD-40 = badness
Discussion in 'Computers, Games, Electronics etc' started by GlassHeadlights, Sep 17, 2009.
  1. GlassHeadlights
    Calgary, AB
    The headphone jack on my 2nd gen iPod touch stared to go out, I squerted a bit of WD-40 in there and fixed the problem but it seeped into my screen and it's f-ed up. Colors and defination are fine but the brightness is blotchy all over the place. Every thing still works fine, I'm typeing from it right now.
    Do you thing it will kinda, dry out?
  2. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    considering it's not water... nope. :p
    never would have thought to try to fix an electronic device by squirting liquid into it.
  3. 95b16coupe
    95b16coupe New Member
    ct
    you sir are an idiot.
    everybody knows electronics and water don't mix. *shakes head*
  4. eg6sir
    ^^^ agreed... why the hell would you squirt wd40 into your ipod?
  5. DESPAIN
    flower mound TX
    headphone jack sticking? lube it up.....lmao
  6. D16SiHatch
    D16SiHatch New Member
    yea man i dunno what you were thinking but you've definitely muffed it up for good
  7. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    LOL best thread I read all day
  8. GlassHeadlights
    Calgary, AB
    WD-40 has always fixed electrical problems I've had. I only use it for music and email anyway. It'll hold up until something better comes up, like a touch with a camera.
    But there was still nothing worse than both sides cutting out while you walked with it in your pocket. Yes I tried to clean it out with a rag before the wd.
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    lmao wd is 70% water
  10. tabKola
    tabKola New Member
    Tewksbury MA
    Should have put the WD-40 on a paper towel and then put the paper towel in the headphone jack. Worked like a charm on my nano.
  11. 95b16coupe
    ct
    or spray the male plug on the headphones instead of directly into the ipod.
  12. D16SiHatch
    exactly what i was thinkin
  13. klyph
    klyph Dismember VIP
    North Pole, AK
    Open the case, remove the battery, and flush the whole thing with denatured alcohol (100% alcohol, not rubbing alcohol which is mostly water) repeatedly and thoroughly. Then allow to dry in a well ventilated environment for about a day or at least overnight. reassemble and see if it worked. The alcohol should displace any water trapped in the screen and then evaporate away.
    Now, if it is the petroleum products in the WD-40 that are trapped in the screen, you will have to use some type of solvent or soap to remove them which will be MUCH more difficult.
  14. GlassHeadlights
    Calgary, AB
    Is there any way I can "pop" open without breaking it? After my Nano broke I tried to open it and ended up destroying it.
  15. Drake
    Drake Well-Known Member VIP
    Apple does not allow mere mortals to open an Apple product. Only the had of The Jobs it's self can coax open Pandora box!
    This thread has also made me laugh. Well done!
  16. klyph
    klyph Dismember VIP
    North Pole, AK
    Yeah, screw apple products. See if your warranty will cover intentionally squirting petroleum products into your electronic device :roll:
    What you should have used was this:
    And you should have applied it to a q-tip and swabbed the inside of the headphone jack with that.
  17. GlassHeadlights
    Calgary, AB
    Lesson learned, i'm glad you guys got a good laugh out of this.
  18. awptickes
    MD
  19. 95b16coupe
    ct
    you really are that stupid aren't you?
    next time it's dirty, grab a sponge and some dish soap to scrub it clean.
  20. caboose
    caboose USDM to the bone
    Hamilton, MI
    If WD-40 fixed the headphone jack... then I imagine you could fix the lcd with some drygas.
