ok so i got everything together started up and all now it idles fine but when i give it a little bit of gas to let the clutch out it bogs down and wants to die then i open it and open it and it keeps boggin then it will just start revin really high once the throttle plate opens, why is it bogging down and stuttering when i only give it small amounts of throttle? please anyone its a d16z6 obd1 with a p28 chipped ecu
im using a non vtec dizzy and the mounting doesnt line up with the holes so im guessing thats my problem, it is mounted solidly on there though
Adjust your distributor timing, that will solve your issue. Is the head a d16y8?, if so use a D15b7, because it mounts properly to a y8 head and you can do necessary timing adjustments.
