Ls/gsr
Discussion in 'General Tech and Maintenance' started by INJEN78, Oct 29, 2007.
  1. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok i need to know if GSR pistons/rods/crank will work properly on an LS block?
    i just bought an ef and im trying to put together a motor
  2. SlushboxTeggy
    New Jersey
    Short answer-No.
    Long answer- Yes, but its not worth it.
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok well i have nothing to go in the rex...my friend has an ls block and the gsr stuff..soo what do i have to do,,and what are the reprocussuions
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok i rlly need to know asap..plz sum1 help me
  5. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    ls rods + gsr pistons = +1 compression
    you need to shave the sides of the ls pistions to have them fit the gsr pistons. I'd keeps LS parts throughout the rest of the bottom end.
  6. brian11to1
    brian11to1 Senior Member
    In short, you should not attempt this.
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    why not attempt??the parts are free..on another forum..i was told by a couple of reputable guys that itd work
  8. brian11to1
    I never said it wouldn't work. I said YOU shouldn't attempt this... meaning I don't think you have the know how to assemble a reliable engine.
    So with that said, do you have any experience assembling an engine... any at all?
  9. dtob
    dtob New Member
    Why not just find a cheap ls engine complete?
  10. tartymctang2357
    tartymctang2357 Grand High Wizard
    philadelphia
    if you have the gsr internals, yes they'll fit inside the ls block, to keep things simple, use gsr rods with the gsr crank and ls rods with the ls crank if you're gonna use either of those or else you need to visit a machine shop
    1 person likes this.
  11. INJEN78
    INJEN78 HS LEGEND
    OHIO
    no i dont but my friends do..and they build badass motors
    lol thanx but i rlly couldnt understand what the hell you meant
    because all the LS engines around CT arent cheap and i already have the parts soo why spend more money than needed?
    thank you for a straight up answer
  12. brian11to1
    Everyone has "friends" that build "badass" motors...
  13. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok hes ase certified in a honda dealership...i pretty sure well be able to figure out sumthing
  14. c97x
    c97x sorry boss, its turbo
    cant find a cheap ls in ct, your joking. arn't you a short drive from nyc. nyc has everything, plus your so gangsta so you will blend right in
  15. ImAHustlaABC
    ImAHustlaABC New Member
    lol
  16. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    lol :werd: Honda was gonna hire me straight outta high school. I mean I knew how to work on cars and do swaps but by no means was I ready or had the knowledge to build a good, reliable motor.
  17. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok well they have built 4-5 motors that are still in the cars running strong..im sure we wont have any problems..and if we do...OH WELL
  18. rainer1386
    rainer1386 New Member
    Then why are you asking questions on here, just ask your friends they should know.
  19. INJEN78
    INJEN78 HS LEGEND
    OHIO
    i figured id try to get some answers on here first..i thought this what was the forum was for...
  20. formby
    formby learning in progress
    OP
    DIE!
    lol omg lmfao lol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfaolol omg lmfao
