LS swap, axel?
I want to get new rims for my car right now the bolt pattern is 4x100 if i do my swap and use the different axels am i going to have to change rims or will the bolt pattern stay the same, im a little unclear about this. Thanks.
the axle is wat goes from the tranny into te hub,the hub is what has 4-5 studs that your wheel goes on,then you put lugs on that
