LS/vtec 92 integra. Which pistons
Discussion in 'Engine Building' started by jits1980, Aug 8, 2007.
  1. jits1980
    jits1980 New Member
    hey guys im doing an everyday driver ls/vtec. i have a 92 integra ls. I am going to keep the block and getting a 95 gsr head. i am doing a complete rebuild on the block and getting new valves for the head as some of the valves are craked. i am going all gsr pumps and timing belt.
    -Which Pistons should i buy the p73 integra type r, pct civic type r or b16a civic si?
    -Also should i invest in some apr rod and head bolts?
    Please help 1st time builder here.
  2. jits1980
    jits1980 New Member
    i am using stock cams. i dont know what compression i am running. what do you suggest?
  3. eg6sir
  4. LsvtecEg6
    LsvtecEg6 New Member
    I agree...Using stock cams would be ideal for the p30's. If you're gonna use stock cams why up the compression? A "stock" ls/vtec is good for a daily driver.
    Edit: I know p30s will raise the compression. I meant keeping it moderate. lol. Didn't want to confuse anyone.
  5. eg6sir
    compr. would be about 11.8:1 with p30s.. with JDM p73s it'll be about 11.5:1
  6. LsvtecEg6
    That's wierd. I always thought it would be closer to 11.2:1. Especially with a stock head. Everyones wrong sometimes. I may be missing someting here but aren't p73's higher in compression?
    Nevermind...just used that calculator. That thing is neat. Aren't p30's also easier to use with stock rods. I know there's something you need to do to get p73's to fit with stock ls rods. Am i correct.
  7. eg6sir
    the GSR head on the LS block will make the compression a little higher than a b16/itr head due to the smaller combustion chamber.. and no the p73s aren't higher in compression than p30s...
