LS/VTEC Build Need Help
jits1980
Hey guys im building a 92 ls/vtec. I was going to buy a rebuild kit to rebuild the engine while we did the conversion. My ? is if i buy a GSR rebuild kit it includes
Eristic Head Gasket Set, ACL Duraglide 780 Bearings Kit
NPR Chrome Pistons Rings 81mm, JDM GMB New Water Pump
Koyo Timing Belt Tensiner, New JDM Timing Belt
New JDM Oil Pump, High Quality Gasket Kit Includes:
Multi Leyer Head Gasket, Valve Cover Gasket, High Performance Viton Valve Stems,Intake Gaskt, MLS Exhaust Gasket, Cam Seals, And More!!.
Will these Parts work on the LS Block b/c i wanted to use the GSR oil pump water pump and timing belt or should i buy a ls rebuild kit and have them put in a GSR timing belt, oil pump and water pump. Please help i am new at this
thanks
