Ls Vtec Guys Read This!
Discussion in 'HYBRID -> EG-EK / DC' started by CriztheWiz, Apr 24, 2003.
  1. CriztheWiz
    CriztheWiz Banned
    I see a ton of disimformation about this set up or the same questions asked over and over again. If you want to know about the set up go to this link read it all then if you still have a question you can ask me or someone who has a LS VTEC. Please no more "my friends friends sisters brothers cousin said..."
    http://allmotorhonda.com/techpages/feature...les/charles.htm
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    You know,a link would help.
  3. punkposer0318
    punkposer0318 Junior Member
    Austin TX
    haha my thoughts exactly...
  4. CriztheWiz
    CriztheWiz Banned
  5. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    There is no actual info there. Just a description of someone's setup.
    It's a cool setup though.
  6. B16
    B16 Super Moderator VIP
    yay area, CA
    ya, all i see is info about the setup, but doesn't answer any questions, and i dont see where it contradicts anything that has been said about ls/vtec's on this board...??..
  7. CriztheWiz
    CriztheWiz Banned
    "my friend that works at a shop is telling me that the motor wont last after 15k miles after the swap due to heat and what not... " quoted from other post
  8. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    all i have to say is
    "don't believe the hype"
  9. lsvtec
    That goes in both directions. When built properly it will last just fine. But don't be expecting unrealistic number out of it. You are not going to see 250hp and 180 lb/ft by just adding a VTEC head to an LS bottom end.
  10. D16z6CrxDx
    D16z6CrxDx Senior Member
    my B20-v that i built my self is still running around 20k miles later (right after i built the motor i installed it inot my ef CRX which got totaled 2 days later, so i sold the motor) so i think that proves that wrong, but then again i didnt build it much i just slaped the b16a2 head onto the b20z blcok and i routed all the fittings and everything really good and i bought good fittings and all OEM gaskets....
  11. punkposer0318
    Austin TX
    alright this question is for someone that actually did the swap themselves... like actually worked the whole thing themselve.. alright... im thinking about doing this to my 91 teg. so im going to need a first gen b16 head. im reading up on the swap at http://www.c-speedracing.com/howto/lsvtec/lsvtec.php and it says that. "Pictured here is the back of a B18a block. Notice there is no knock sensor. The knock sensor came on the 92+ VTEC engines only. If your block doesn't have a knock sensor, you will need to located a hole for one" so im going to need to buy a knock sensor for the swap? also... on relocating the dowel pins which way did ya'll do it? the first way moving them on the exhaust side..... or on the intake side? the intake side looks easier.... but from the picutres it only shows there being 2 dowel pins.... and both on the same side of the block... im confused.... they both go on the same side.. or you have to do both steps and what head gasket would i need to buy and modify for this swap? the factory ls?
  12. xj0hnx
    C.C.TX.
    No,run an ECU that doesn't look for it.They aren't a bad idea,they just throw kinks into things.
  13. punkposer0318
    Austin TX
    alright then what ecu should i use? how would vtec know when to kick in?
  14. pills_PMD
    New Albany, OH
    vtec knows to kick in when the ECU grounds the solenoid and engages it...
    i dont run a knock sensor and i use a p28/hondata setup...
    i would suggest hondata to anyone
  15. pills_PMD
    New Albany, OH
    and you cockblocked his thread... start your own.
  16. punkposer0318
    Austin TX
    alright thanks i think im going to use a 92 gsr ecu the b16 head my stock ls bottom end and my stock tranny for now... thanks for the help guys yall are badass.
