brian_19simoes
Motor:
-95 ls block bored to 82mm
-b16 pistons
-arp head studs
-arp rod bolts
-golden eagle coversion kit
-shortpined rods
-typer oil pump
-gsr water pump
-greddy timing belt
-all seals and gasket replced when motor was built
-94 gsr head
-port and polished
-arp head studs
-type r valves
-skunk2 springs and retainers
-skunk2 stage one camshafts
-aem cam gears
-hp racin intake manifold
-gsr throttle boby
-password jdm oil cap
-candy yellow valve cover
1500.00 firm
Tranmission
-96 ls tranny
-competition clutch
-7.5ib FIDANZA ALUMINUM FLYWHEEL
300.00 firm
obd2a-obd1 conversion harness
60.00 firm
p28 ecu
80.00 firm
Header
-custom built header with 2.5in exhaust pipe looks like hytech
300.00 firm
-b16 pistons
-arp head studs
-arp rod bolts
-shortpined rods
-typer oil pump
-gsr water pump
-greddy timing belt
-94 gsr head
-port and polished
-arp head studs
-type r valves
-aem cam gears
-gsr throttle boby
1500.00 firm
Tranmission
-96 ls tranny
-competition clutch
300.00 firm
60.00 firm
p28 ecu
80.00 firm
Header
300.00 firm
