brett_the_madman
ok this is probably going to be long but i was wanting to get some more power out of my 92 GS teg. i am planning on doing the ls/vtec but before i order everything and start building i was wanting to know if i am doing everything right and if everything will run good on the setup i am using for use as a daily driver on pump gas. here is a list of everything i am planning on doing. please let me know if there is something i am missing or something i need to change or if any of this is unnecessary. thank you. oh ya and the only mods i have already is the typical i/h/e
itr crank
VTEC water pump
itr/gsr oil pump
gsr timing belt
golden eagle ls/vtec kit
gsr distributor
b16 intake and throttle body
stage 3 clutch
gsr computer
Port and Polish
Balance the rotating assembly
JDM p30 81mm b16a pistons
LS Rods
GSR tranny
SI head with skunk2 stage 1 cams, Type-R Valve Train, Skunk2 cam gears, Type-r Inner
and Outer springs w/ retainers
P28 rechipped with a higher rev limit for VTEC
VAFC
RC 310 cc injectors
Holley 255 pump
adjustable FPR with gauge
crank brace/girdle and an Oil cooler from a GSR 94-95 or ITR
ARP Rod Bolts
Clean & Hone cylinder walls
Replace the main and rod bearings
Replace all gaskets (ie. Oil pan gasket, rear main seal, Oil return gasket, oil filter, valve cover gaskets, intake manifold)
itr crank
VTEC water pump
itr/gsr oil pump
gsr timing belt
gsr distributor
stage 3 clutch
gsr computer
Port and Polish
LS Rods
GSR tranny
VAFC
RC 310 cc injectors
Holley 255 pump
ARP Rod Bolts
