ls won't fire injectors not working
Discussion in 'HYBRID -> ED-EF / DA' started by pappaj, Jun 2, 2010.
  1. pappaj
    pappaj New Member
    woodstock
    I just finished putting ctr pistons in my ls and port matching the head. I put it all back together, it turns over has good spark, timing is correct. I am pretty sure the injectors are not firing, dont have a noid light. when I turn car to on and check the injector plug there is power there. I pulled out the plugs to see after trying to start and they don't smell like gas so thats why I assume that the injectors aren't firing. Its and obd0 motor with same ecu, injectors, and resistor box. I am wondering if anyone has some ideas for me to check. I have check tstat housing ground. fuel pump is running.
  2. pappaj
    pappaj New Member
    woodstock
    Does anyone have some ideas for me to check, for possible causes for injectors not firing. Fuel pressure is there, have tried two different ecu's two different sets of injectors, two different resistor boxes, I'm stumped, please help me.
  3. pappaj
    pappaj New Member
    woodstock
    anyone, need some help please. Need some possible causes for injectors not working.
  4. pappaj
    pappaj New Member
    woodstock
    well the injectors are working now but still no fire have been trying to adjust fuel pressure and timing, sometimes it wants to fire but won't not sure what i'm missing.
  5. b18a1crx
    b18a1crx b18a1crx
    conway nh
    is your main relay woking?
  6. b18a1crx
    b18a1crx b18a1crx
    conway nh
  7. danny shy
    danny shy New Member
    thats it prolly mine did same thing
