Originally posted by xyswany@Dec 3 2003, 07:27 PM
do a compression check on it, that will tell you if it is a gasket, rings, cracked head or otherwise. as for your idle look here. https://hondaswap.com/articles/viewer.php?id=55
Originally posted by crxtunerfan@Dec 3 2003, 06:54 PM
4. your car revving at 3k when u start it cold is normal.
Originally posted by steelbuster@Dec 3 2003, 08:27 PM
Definatly moisture in the oil like crxtunerfan says....up here in the frozen north we see that alot from condensation of blowby gasses during the winter...we shorten oilchange intervals to combat this. Change oil and see if it shows up again.
Pappy
Originally posted by Slammed89Integra@Dec 3 2003, 09:49 PM
I've done my fair shair of head gaskets, and usually this is the typical sign. Well actually 95% of the time, this is a symptom of a blown headgasket.
