Mini me help
Discussion in 'Civic and del Sol - EG and EK' started by Del_Sol_JJ, Nov 9, 2015.
  1. Del_Sol_JJ
    Del_Sol_JJ New Member
    I have a 95 del sol with a D16Z6 in it that's blown up ... I know someone with a mini me engine I'm wanting to buy and put in ... Are the mini me engines any good ??
  2. E_SolSi
    depends
    depends on what was used
    depends on how it was put together
    depends on what condition its in
    way too many variables
    it can be a great little engine that is comparable to a factory SOHC engine or it could be a POS
  3. Briansol
    what blew up on your car?
  4. Del_Sol_JJ
    Bottom end is shot pretty much ... Replaces rod and main bearings but it's still knocking hard in the bottom end
  5. E_SolSi
    how much are you looking at spending on the mini-me
  6. Del_Sol_JJ
    The guy is selling it mated to a 5 speed trans for $350 ... It runs good with no leaks ... Someone put it in an integra body and he took it out for a B engine to go in
  7. E_SolSi
    for $350 might as well go for it
    even as a stop gap, it will give you a running engine while you save for another swap without dumping a bunch of cash
  8. Del_Sol_JJ
    Yeah I think that's what I'm going to do ... I also have an eclipse that I'm fixing up so I need one to drive lol
  9. Del_Sol_JJ
    Thanks for all the help guys ... The mini me is in and running like a champ ... Better than that D16Z6 was
    Briansol and E_SolSi like this.
  10. E_SolSi
