I've got a 89 CRX with a Mini-me... It has a 1.6 a6 block and a 95 si head, intake, and throttle body. The car used to run great with a full 95 si engine however I threw a rod in it, thus the reason for the a6 block. It will start with a little bit of gas from the pedal and it will run strong. However, it will stall out if I let it get into the 750-1000rpm range. What could be the problem? What are other peoples Mini-me's idleing at?
