so, questions here
just looking for opinions for now...
so i have a 91 std civic hatch, was DPFI 4 speed, 176K miles, with a/c...
is now DPFI, 5 speed, 105K miles still with a/c
A/c is important so it needs to be retained...
now my question is, if you were in my shoes would you go with a SOHC vtec head on the stock block, or would you do the B series swap...
I'm thinking about $$ to HP numbers here...
which ever motor i choose will eventually be getting a turbo as well...
the B series has lots of turbo and vtec head swap potential...
but if i do a mini me, all i need is vtec wiring and MPFI conversion, and that supossedely makes 135 horse power, more with a shaved head, but then higher compression which is not so good for a turbo...
the motor in the car now is not stock, stock had 175K and smoked REAL bad... new motor had 105K and WAS mint, then the timing belt popped, and now it ticks and knocks and smokes and all that good shit...
so i'm assuming the damage is just in the head, and that the lower end is still solid enough for a turbo and vtec head swap...
so what do you guys think?
the b series swap would be done with a smacked up integra running betwee 300 and 500, but then i still need MPFI conversion and mount kit and axles and cable trans if the car doesn't have one...
and the mini me is said to be able to make power to 8K rpm's which would be GREAT with a turbo...
