mini me swap?
Discussion in 'Civic and del Sol - EG and EK' started by weggies4life, Mar 23, 2008.
  1. weggies4life
    weggies4life New Member
    ive herd about the mini me swap a few times but still dont get what the hell it is n all about it so if someone could tell me somethin id appriciate it alot
  2. BrutalB83
    Rochester Hills, MI
    Seriously? Do some research. It isn't a hard concept to understand and there's about a billion articles on the Internet about it...
  3. team_spoold
    team_spoold New Member
    under the arch in good ol MO
    you swap your existing head for a diff one its really simple undo your intake manifold timing belt distributor exhaust manifold take off old head scrape old head gasket off the block install new head gasket install new head put intake manifold exhaust manifold distributor and timing belt onto new head and retime you car see? easy as 1-2-3!
  4. weggies4life
    o thats it i thought id be harder than that
  5. BrutalB83
    Rochester Hills, MI
    And run wires for VTEC and swap the ECU out for a P28 or something else that will run the motor correctly.
    Here, there's a wonderful website called "google" where you can actually search for stuff on the internet. I searched "mini me faq" and came up with a bunch of different write-ups on how to do it:
    mini me faq - Google Search
