Mini-Me Swap
Discussion in 'General Tech and Maintenance' started by INEEDHELP, Mar 26, 2004.
  1. INEEDHELP
    INEEDHELP Junior Member
    I have a SOHC ZC is it possible to drop in a VTEC head? if so, what should i use D16Z6?
  2. JUN-DA6
    JUN-DA6 Junior Member
    yes, it is possible to put a VTEC head on your SOHC ZC. You can use D16Z6 head from 92~95 Civic or D16Y8 head from 96~00 Civic. If your car is OBD1 use OBD1(D16Z6) head. Same as OBD2 use OBD2 head(D16Y8) because the distributor fitment will be better. Make sure you get complet head, distributor, intake manifold with all sensors,and ECU. Good Luck.
  3. 91SiZC
    91SiZC Junior Member
    um i have a 4th gen si and its OBD-0 so how can i do that? cause i also have a ZC... thanks
  4. AlphaCivic
    AlphaCivic Member
    San Diego
    for obd-0 get the jdm d15vtec head.
