MiniME
Discussion in 'Engine Building' started by Hondatrix, Apr 20, 2009.
  1. Hondatrix
    Hondatrix Mr Honda
    SA
    A mate built a D16A7 with D16Z6 head and now he has oil pressure problems, so much so that VTEC disengages above 6500 rpm, anyone had this before?
  2. awptickes
    MD
    Try these:
    Hook up an oil pressure gauge and tell us what the pressure reads
    New oil filter
    heavier weight oil (just go one step up)
    Did he remove the oil jet from the block?
    How new is the oil pump? Is the screen on the oil pump pickup clean?
  3. Hondatrix
    Hondatrix Mr Honda
    SA
    Thanks, the pump is new, screen was cleaned. I will tell him to change the oil filter and oil.
  4. sevenhillsbilly
    sevenhillsbilly New Member
    and to make sure did he take the oil control jet out?
  5. Hondatrix
    Hondatrix Mr Honda
    SA
    Yes he did, it's on his work bench....(-: Car made good power at 8000 rpm , once, then lost VTEC at 6500. Strange one, never had it before.
  6. awptickes
    MD
    How's the oil pressure sender? What about the filtering material on the vtec solenoid?
  7. Hondatrix
    Hondatrix Mr Honda
    SA
    OP sender is new, and re-checked ..the solenoid might be the culprit. Thanks
  8. awptickes
    MD
    Bench test the solenoid before you replace it.
    Also, check to ensure that the ECU is powering the solenoid at the proper point. It could be a burned out ECU component.
  9. sevenhillsbilly
    just out of the blue here how bout a weak oil pump or a cloged up oil pump?
  10. awptickes
    MD
  11. sevenhillsbilly
