Hi those anyone as the missing link bypass valve? I want some really good pics. I want to know how the it works, with a spring and ball i heard. I want to know which side is the ball and which side is the spring. Can anyone help me? Thnx
ummm i think you are thinking of something else. the missing link is a device that fools the MAP sensor on the ECU into thinking it is always 0 or 1 psi. anymore than that, and the ecu will throw codes. So, the missing link takes the real reading from the map sensor, and translates it into a little above 0 psi.
i know that that is the function. But i want to make one my self. That's why i want to know how it works(the internal)
i don't think it's electronis, otherwise it's the same as hks feul cut defencer. It works whit ball and spring
no its not electronic, You can make it with a couple if small tubes, Let me find the link to make it <_<
