Mitsubishi TD04 Turbo Wastgate
Discussion in 'Forced Induction' started by CiViC>ALL, Dec 31, 2007.
  1. CiViC>ALL
    CiViC>ALL New Member
    i just bought a TD04 turbo kit from a friend of mine, When i finally received it i was looking at it and noticed i couldn't move the wastegate bar. Is this a problem? Should i be able to move it by myself?
  2. TurboMirage
    unclip it from the turbo and see if you can move the flapper.
  3. CiViC>ALL
    yeah i can move the flapper
  4. badasscrx
    badasscrx New Member
    Casper. Wy
    how hard did you try???
  5. CiViC>ALL
    i didnt push that hard because i didnt want to bend it
  6. CiViC>ALL
  7. badasscrx
    Casper. Wy
    Well the aping in there is like an 11 psi spring so it should be fine
  8. CiViC>ALL
    11 psi?!? i though they were around 7?
  9. CiViC>ALL
    anybody else? how many psi the turbo pushes and if i should be able to move the wastegate arm?
  10. explosivecivic
    explosivecivic New Member
    I heard some people get 11 psi but commonly your looking at 6-8 psi. I'm acually putting a td04 on my car next month.
    The waste gate arm is a BITCH to move. To test it use a large suringe on the end of the hose to creat vacume
    Sorry about the spelling
  11. badasscrx
    Casper. Wy
    Depending on what TD04 you got most likely the 14B you can get 20 whitch is maxing it out
  12. CiViC>ALL
    i tested it and the wastegate actuator moved with the i had 11 psi. i guess what i need to know now is how to lower the psi to the 6-8 psi range.
  13. newb
    newb phresh VIP
    Backwoods Northwest
    You can run that turbo to 22psi, and you can even mod it and make it hold 28psi, and doin that is still cheaper than buying a bigger turbo. They spool fast too, they can make a real nice setup.
  14. badasscrx
    Casper. Wy
    Yeah with porting the compressor housing buying the 16g or 18g compressor wheel. Might as well have it rebuilt while you've got it apart so you looking at at least $200 or you could just buy a real 16g
  15. CiViC>ALL
    Yeah i knew they were a good turbo but how can i lower the psi? Can't you cut the actuator bar, thread it, and but a long nut in there. I though if the bar was longer it might lower the psi by leaving the wastegate flapper open.
  16. badasscrx
    Casper. Wy
    i dont think that really works. get a boost controller
  17. Briansol
    boost controllers can only go UP from the base spring, not lower
  18. CiViC>ALL
    yeah boost controllers can only trick the turbo into thinking there is less pressure than there is
