more power
Discussion in 'Accord' started by critchy88, Dec 15, 2007.
  1. critchy88
    critchy88 New Member
    Newfoundland Canada
    well i want to do sum things,but not lookin for engine swap or turbo...i wanted to know wat options i have.. i no a catback,and headers,and cai will do a little..anone know wat numbers of hp to expect?and wat other things could be done? just askin for ideas...a good cold air is 1 on the list,one hat goes down inside the wheewheel not behind the battery, but lookin to go futher .open to suggestions^_^ o yeah 95 ex..f22b1
  2. BrutalB83
    Rochester Hills, MI
    The gains you get from I/H/E will depend on the quality of the parts you buy. Even so, don't expect huge gains from bolt ons. Think maybe 10 horses to the wheels, and that's with expensive stuff.
    If you want more power than that without a swap or turbo you could look into a cam, head work, tuning, etc. You could also swap a dual-cam head onto your F22 block. An H23 head and intake manifold would be nice, or go all out and do an H22 head.
    Nitrous is an option also.
  3. philyphreak2127
    philyphreak2127 Back in the Game
    Littleton, co
    go h22 head, i/h/e for sure. that will give you some power.
  4. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    is that even possible? F22 bottom with H22 head? =/
  5. philyphreak2127
    Littleton, co
    It is possible. But I think that only works with the f22.
  6. BrutalB83
    Rochester Hills, MI
    I wouldn't have suggested it if it wasn't possible. I personally know someone with an H23 head on their F22A1 Prelude motor, and I've seen write-ups for the H22 head onto on F22 block.
  7. yardeman
    yardeman New Member
    can the h22 head fit on the f22b shoc vtec botton also
  8. Uncle Buck
    Uncle Buck JDMDecals.com guru
    Spearfish, South Dakota
    all F series and H series share the same block casting..... kinda like the D15 to the D16, or the B16 and the B18....
