So i have this d16z6 that has a severe oil burning issue, i got burned on this deal pretty bad...
so i was considering rebuilding the motor, i would like to do the rings and the valve seals...
questions...
if you remove the crank, can you reuse the bearings? or do you need to install new ones?
kinda like a headgasket, you NEVER reuse them, does the same apply to crank bearings?
ring replacement...
is it possible to simply replace the stock rings with new stock rings? i realize if the cylinder walls are scored then you want to bore and get bigger pistons and matching rings, but if you want to avoid getting new pistons and there appears to be minimal piston sloppy-ness can you just use new rings?
questions...
ring replacement...
