My d16z6 Full swap Build
Discussion in 'Engine Building' started by Boondock Saint DX, Oct 22, 2005.
  1. Boondock Saint DX
    Boondock Saint DX Senior Member
    Des Moines, Iowa
    Aem/Injen CAI
    Eldebrock/Skunk2 IM
    ARP Headstuds
    DC header
    Skunk2/AEM Stage 1 Camshafts
    Si/Ex Tranny
    Exedy Stage 1 clutch
    Lightweight flywheel
    p28
    What am i missing? What are some good options to add.
  2. bambam
    bambam Member
    groton, CT
    your best mod for the money would be to throw in some ZC pistons or D16a1 pistons. You'll get more power out of that and a good cam then ALL of those other bolt on's combined. There's really no reason to do a complete bolt-on SOHC motor....unless you raise the compression.
    Good build using basically only stock parts:
    Dohc vtec throttle body
    D16Y8 intake manifold
    ANY 1.6 block (all have same bore/stroke) but best is D16Y8 because of it's lower miles
    ZC or D16a1 pistons
    D16y8 head
    with that combination you're looking at over 13:1 compression.
    Couple that with a sick cam and a nice header, you're looking at 160-170 WHP
    Dont waste youre money on aftermarket manifolds, fuel rails, ignitions, injectors, etc.
  3. Boondock Saint DX
    Des Moines, Iowa
  4. bambam
    bambam Member
    groton, CT
    you just said exactly what i said.
    D16Y8 w/ ZC (P29) pistons
    i think 160 is doable with tuning.
    All the SOHC D16 blocks are the same except for the pistons.
