My Gsr Swap Is Slow!! Need Help!!
Discussion in 'HYBRID -> EG-EK / DC' started by gsrswap2004, Oct 3, 2006.
  1. gsrswap2004
    gsrswap2004 New Member
    HEY PEOPLE.. WELL FIRST OF ALL I'M NEW IN THIS WEBSITE.. SO YEAH.. I HAVE A QUESTION ABOUT MY CAR.. I HAVE A 98 HATCH W/ A 95 ENGINE.. I SWAPPED IT LEGALLY.. WHEN IT WAS DONE SWAPPING.. I TOOK IT OUT TO RACE MY BUDDY'S 99 HONDA CIVIC SI COUPE.. I LET HIM TAKE OFF.. CAUSE THOUGHT I WOULD CATCH HIM IN 3RD GEAR.. BUT NOPE.. HE BEAT ME.. I WAS DAMN.. :mad: I SPENT 3500 ON THE SWAP.. DONT GET ME WRONG ITS NOT DRIVER CAUSE I ALSO LET MY BROTHER IN LAW RACE IT AND STILL LOST TO MY BUDDY.. AND SUGGESTIONS?? HELP!! I'LL APPRECIATE UR HELP... :(
  2. LateApex31
    LateApex31 New Member
    Is VTEC working? Also, 99-00 Sis have much better gearing than your GSR does. When you let someone get out on you like that it takes a lot more HP to catch them. He only had 10 less HP and better gearing.
    Also, a 95 engine in a 1998 chassis isn't legal, but that's irrelevant.
  3. get_nick
    Washington State
    first, stop yelling. take of the damn caps lock. second, you are going to lose if you give someone the lead. if your motor is stock, i would try getting intake/header/exhaust.
    i think he was saying it was legal as in it isn't stolen. it's a legal swap in most states. only states with emissions laws are hard to get a swap.
  4. tip
    tip Senior Member
    Ennis Texas
    i would check the codes you have because if its slow to the point you are questioning the money spent then you more then likely have some problems
  5. element
    element New Member
    like lateapex31 said 99 SI dont have that big hp diference to a gsr
  6. ef8
    ef8 Junior Member
    Its a b16 coupe and a gsr hatch..The hatch should have definitley got him if it was running right
  7. 1badteg
    1badteg Junior Member
    pull some codes and spend the extra money to get it dyno tuned. also do a compression test to make sure your engine is healthy. all cylinders should be +/-20psi of eachother. you'll thank yourself later for it.
  8. b18JDMcivic
    b18JDMcivic Junior Member
    i've got a full engine swap with tranny, shift linkage, wiring harness, e.c.u., all of it is 100% pure japanese and acoupleof other things done to it. Ive beat a doped out SRT4neon, and a couple other cars and i've also beat an si so i dont now y u didn't beat the si do what (qet_nick) says do that if u want then you have a dopped out fucking civ peace:ph34r:
  9. oopma
    oopma New Member
    you should have taken that 3500 and did a k swap for 2500 and spent the other 1000 on hondata and then you could have gave your friend a five car head start and beat him by 7 cars
  10. ef8
    ef8 Junior Member
    And a K swap is 2500 where now?Your atleast $2500 short and thats just for the price of the engine.
  11. n0re781
    n0re781 New Member
    a whole k-series swap is around 10gs...
  12. k20 eg
    k20 eg New Member
    belton mo
    well you can get a k20 on ebay for about 2k and some change and yes the k s alot better thats what i am going to do with the eg i buy
  13. n0re781
    n0re781 New Member
    plus shipment...etc. im saying the whole thing in your car and ready to go is around 10gs
  14. k20 eg
    k20 eg New Member
    belton mo
    well if you have good friends and know a few shops maybe not 10k
  15. n0re781
    n0re781 New Member
    true
  16. element
    element New Member
    yeah but depends what k series your talking about the k20a-R dosent go for 2ks lolol
  17. k20 eg
    k20 eg New Member
    belton mo
    well no not that one just regular but you can go cheaper if you get a k20 head with a k24 block or k20 head and k20 civic r block or k20 civic r and a regular k20 head
  18. jeffsciv23
    jeffsciv23 Senior Member
    Wa
    meanwhile back at the ranch......
    check your codes to make sure it's actually running right and if none then do a compression test to see if you have any. i have a gsr with P&P head, rockett motorsports gen 2 valvetrain, M24 cams, and 11.5:1cr pistons, skunk2 intake, rmf header in a 92 hatch. i had a cel one time but didn't check it and decided to race a friends car that i should have smoked bad but didn't, fixxed the cel and now its no contest.
    moral of the story: fix your shit somethign isn't right.
  19. k20 eg
    k20 eg New Member
    belton mo
    well hes right
  20. gsrswap2004
    Yeah i dont feel that much of a vtec.. and also it start to kick vtec at 6000 rpm.. isnt it to late.. ?? Check this out i also raced a integra gsr,and also fuken lost.. i was pissed dude.. so what u think man?? what should be done to fixed this probleM??:mad:
