My honda civic isnt as fast as i would like be
thecarguy45
In fact it tops out at 60 mph wat is the porblem im going down the interstate and this baby tops out at 60 i get laughes at by my freinds im a real loser and i love cars maybe the engine i put in it was wrong i need help!!!!! :worthy: :worthy: :worthy: :worthy: :worthy: :worthy: :worthy:
:huh: what year moldle of civic is it and what motor is in it ? what do you mean by "tops out" does the rev limiter kick on ? or does it red line(highly unlikey) or does it just not acelerate ?
lol..look under the hood and feed those hampster's you got runnin that wheel,try upgrading to faster hampster's
well, you own a civic...that should answer your question...
good upgrade with a great starting point is to swap a motor in there
well thanx some of you i dont know what the problem is it just doesnt go past 60 for some reason let me feed that hampster as the fa*** said before.
lol..i was just playin sorry bro..you probably just need a good tune-up,check your timing,get a new fuel filter,get some ngk or denso spark plugs,get a new a new distributor cap/rotor,check your ground connections,get a valve adjustment...tell me how the motor is running exactly..then ill look in my mechanics book and let you know what else it could be
Dude if you want to get answers that wil lhelp you, you need to give us more info on how the car is running. Does it just stop like a fuel cut? Or are you running out of gear? How does it sound when you are stepping on the gas?
no serously it just stops acclerating i dont know wat the problem is it just goes wannnnn wannnnnn and wont go past 60.
This has got to be B.S. If not, what gear are you in when you top out, if you shift, you can actually go faster. Stick or Auto?
err... only 55mph in 2nd?
if I put my auto in 2nd gear..I can get 80mph at redline (7200) d16y7
I have a 2000 SI...2nd gear redlines right around 59-62 mph...it's weird, my Escort used to redline 2nd at 65-67 mph.
if it's not BS, then I think he just needs a tune up really bad... <_<
auto in 3rd can get 100mph...1 or 2 over..but thats all there is..that is if im WOT in every gear.... 4th drops rpm's respectably...but not much power...think i may have gotten my civic to 109mph downhill.....damn d16y7 ....b18c1 & auto to man swap soon :)
Sleepergtx, your SI has a lower 2nd gear top speed, most likely because of gear ratios, may seem funny but it is actually faster. My SI tops second like at 57 MPH, with a 6800 Redline.
