Originally posted by Taco15@Jun 16 2005, 12:05 PM
if the ecu is the ONLY thing that you messed with then i think thats your source. I'm not up to date on HS since i work out of town so you might have alrady done this. swap the ecu to a stock vtec one.  heres one. have you checked the fuses?
[post=512910]Quoted post[/post]
I missed checking the fuses. I'll check it out tomorrow after work. Thanks Also how much psi of oil does it have to been? I have the 4in1 AC tach..Thanks again
