N/A and possibly Non-VTEC
Discussion in 'Integra' started by rickabob, Mar 31, 2010.
  1. rickabob
    rickabob New Member
    Im whippin a 1990 Integra RS. my stock tranny took a shit on me, so i bought a S1 B16A tranny for $300, and that is currently in the car.
    Only other upgrades i have done to her is Intake and a muffler that was on it when i got her.
    i want to keep it N/A, and possibly Non-VTEC
    Im needin some suggestions before i start buyin any parts
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    What exactly are your goals?
  3. rickabob
    rickabob New Member
    i just wanna build a reliable motor with plenty of power
  4. rickabob
    rickabob New Member
    What other B-Series parts will bolt up to the B18A1?
  5. K2e2vin
    Raleigh, NC
    B16 pistons? They'll give you a nice bump in compression. You can use B18C* pistons with milled rods.
    Pretty much just do your typical bolt-ons, mild port work(if anything just clean up casting imperfections), and I believe Crower makes cams for the B18A/B. Don't forget to get it tuned!
  6. Magana559
    Magana559 The Warden
    fresno Ca
    check my build thread, Im building a high comp LS.
    Once you know what you want to do i can help you.
  7. rickabob
    rickabob New Member
    all right, i know im wantin some high compression pistons.. and i believe the B18A1 is cast-iron sleeved stock, so it should hold up
    also, do i have to have VTEC parts to use parts off of another VTEC motor? or is that just for the head work?
  8. K2e2vin
    Raleigh, NC
    stock sleeves should hold up well for NA so long as it's not overbored past recommended specs(I believe service limit is 81.5mm).
    I've seen people use VTEC oil pump and water pump in LS/VTEC builds, so if you're going to be spinning higher RPM then I'd say those would be recommended.
  9. Magana559
    fresno Ca
    The b18a/b dose just fine with stock sleeves up to 83mm with street all motor setup.
    You can use GSR water/oil pumps on a LS block but you have to run GSR timing belt.
  10. Scorchin Civic
    Scorchin Civic Senior Member
    Irving, TX
    What about going to 84mm with a LS block? If you think about it the B20 is damn near the same as a B18 but it has 84mm sleeves.
  11. Magana559
    fresno Ca
    b20 sleeves are a bit thicker than what people think. B20 sleeves are not LS sleeves bored out to 84mm.
