need advice/help
tankizk
I have a 94 accord with a blown f22b2 that I'm swapping to a jdm f22b1 vtec, my question is will I have any issues doing the swap? I have the ecu for the vtec, but is there anything else i might need also.....thanks
not sure.. i'm not too familiar with Accords
swap is a simple drop in and bolt it all back together. Did your new motor come with its own wiring harness ? If it didnt . your going to have to run 2 wires back to the ecu for the vtec. As far as yout distributor should work fine. 94,95 all the same no matter what F22 is in there.
