NEED HELP H22A4!!!
Discussion in 'Prelude' started by That_fly_bb4, Nov 29, 2015.
  1. That_fly_bb4
    That_fly_bb4 New Member
    So I bought 93 Prelude with h23 in it swapped it out with h22a4 it's running sounds good but it won't rev past 4000rpm someone help me
  2. get_nick
    Washington State
    Sounds like the ecu is in "limp mode". Try to reset the ecu or swap out with a known good one.
  3. Briansol
    any check engine lights? what ecu are you using? assuming p13, did you wire everything in that the p13 ecu needs?
    wickedlude5150 likes this.
