need help! im a noob!
Discussion in 'Civic and del Sol - EG and EK' started by 97CIVSI, Apr 28, 2011.
  1. 97CIVSI
    97CIVSI New Member
    mobile al
    Im running a D16z6 how do I change my vtec its set to run all the time...
  2. Briansol
    you don't, shouldn't, and it will only make your car slower.
  3. 97CIVSI
    97CIVSI New Member
    mobile al
    Thanks for the tip... any idea what there is I can do to this engine to make it run a little quicker? It already has the basics,header, full catback and cold air intake... im really not wanting to get into the guts of it basically bolt on mode for now. I plan to try to build up an H22 later
  4. 97CIVSI
    97CIVSI New Member
    mobile al
    Thanks for the tip... any idea what there is I can do to this engine to make it run a little quicker? It already has the basics,header, full catback and cold air intake... im really not wanting to get into the guts of it basically bolt on mode for now. I plan to try to build up an H22 later. Id just like it to run a little better till then
  5. Briansol
    just save for the h-swap. dumping anything into the d just puts your further away from the h.
  6. 97CIVSI
    97CIVSI New Member
    mobile al
    That's what I thought too... to turbo an H should I build the bottom end or will the stock parts do ok? What needs to be done to turbo and have a nice dependable daily driver. Thanks for your input dude I appreciate it
  7. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    what are your power goals?
    what year h22 are you going to get?
  8. Briansol
    If you're going to build the bottom end, you have to sleeve due to the FRM sleeves. So, either stay stock and go modest, or be prepared to dump 10+k on a full build to go big (and that's not counting the turbo kit/items)
  9. 97CIVSI
    97CIVSI New Member
    mobile al
    I found an h22 out of a 98 prelude I don't want to go crazy with it but I wanna be faster... top speed for me is like 127 with my z6... but the guy says fir the engine annd trans (84,000 miles) wiring harness and ECU he will let me have it for $750... good deal or no?
  10. UNDR8D
    UNDR8D ...has a job!
    8OH!5
    I usually try just pushing the gas pedal as hard as possible. I've estimated that to be good for at least 12.7 hp.
  11. BrutalB83
    Rochester Hills, MI
    Do you frequently do top speed runs on a track? If not, then I don't know why you'd need to be going 127 mph on a consistent basis, or why you'd want to be be traveling at speeds faster than that...
