I had a B18B1 bottom end with a vtec b16 head in my 99 civic.. I took the b18b1 out and just put in a b18c1 bottom end. what would I have to do to my b16 head to make it work on the new block?
Return it to its pre-LS/VTEC configuration (back to factory) since the B18C bottom end is already set up for a VTEC head.
By the way, if you post and want to use formatting tools to underline something, just use the edit tool to fix your post- don't double up and create another thread. I deleted the other one with the messed up formatting.
