please, someone help me out here
ok, i got my engine but its a obd1 b18c and my car is a obd2 hb. what do i need to make this swap work right? lets see, i got the skunk2 obd conersion harness, and the mounts to make it fit. now, someone told me that i'll need to get an 96+up b18c obd2 distributor, injectors, and maybe alternator? is this true??? and, does anyone know if a obd2 b16a distributor will work on my swap? o, and how should i got about the engine harness? i'm a little low on cash after buying the engine. so my friend suggest to just use my stock dx engine harness, and do the vtec wiring. so, i said ok. but i didn't know that you have to cut the connectors from the obd1 gsr harness and use it on the stock obd2 dx harness. is this right??
i'm just so confuse about all this obd crap. but any help will be soooo great. thanks a million, gsrjennie.
