NEED HELP WITH SETUP!
Discussion in 'Forced Induction' started by RED_95_GSR, May 25, 2005.
  1. RED_95_GSR
    RED_95_GSR Junior Member
    im finally ready to build my motor and i need a little help on my setup.......
    my plans as of right now are:
    -top end-
    crower valves, springs, and retainers
    crower turbo race cams
    crower cam gears
    portflow full race pnp
    -bottom end-
    crower 2.0 stroker kit w/ 8.5 CR
    import builders sleeving
    -fuel system-
    aem rail,reg, and filter
    255lph fuel pump
    550cc rc injectors
    hondata
    i wanna make somewhere b/w 500 and 550 whp, i plan to piece together a turbo kit and i need help with turbo selection. i am thinking about going with a turbonetics T4 w/ a tubular stainless manifold, 3" stainless downpipe, spearco f/m intercooler, 3" intercooler piping, turboxs BOV and boost controler.
    does this setup look ok for the numbers i am hoping, or am i on the wrong track? i am kinda new to boost so any help would be greatly appreciated. also, i am worried about turbo lag, any suggestions?
    thanks
  2. CRXSI91
    CRXSI91 Senior Member
    it looks pretty good..i just hope u have the money for that setup
  3. RED_95_GSR
    i have 10k to spend on the motor and the transmission
    i was planning on running an ls transmission, dues to the longer gears, along with a lsd
    does this setup look like it will yield around 550 to the wheels with minimal turbo lag and good throttle response?
    also, what is a reputable company that does custom stainless turbo mainfolds and downpipes?
    thanks
  4. formby
    formby learning in progress
    jdm itr tranny is where its at but buy onne from here
    3.5k
  5. formby
  6. RED_95_GSR
    the jdm itr has short gears, i thought that with boost you wanted long gears so that you could stay at optimum boost for longer?
    i already have a gsr tranny, would i be better off to just rebuild it and use the lsd than to go with the ls tranny?
  7. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    GSR>LS Stick with the GSR and sure, add LSD to it too. GSR stock is stronger too. I believe it has a stronger diff.
    Shorter gears = faster accelaration.
  8. CRXSI91
    since no ones answering your Q...i think u should go with the Sc-60 or sc-61....those turbo's support up to 500 and 600 horsepower,and would be more sutable..im sure a T4 could make it that high too,but its all on how close u want to cut it...
    as long as u do full upgrades....3'' exhaust...660cc or 720cc injectors..big fuel pump,etc...and tune it right..and build the motor..u will make it to 500 horsepower...
    make sure u get :
    Aftermarket radiator
    Big cooling fan
    Bigger fmic
    3" exhaust piping
    Big Wastegate (38mm)
    Big injectors
    Big fuel pump
    Fuel rail (optional)
    Hondata
    wideband O2 sensor
    Dyno time
    if u build that head and block the way u say you are..and boost it..that will put u at about 500...if done right.
  9. pissedoffsol
    if you want to make 500+ hp, here's the set up.
    you have 10k to spend, good. you'll need it... and a litle more even.
    GSR block:
    Benson Sleeves, 84mm. Contact elaskey@cox.net for info.
    CP pistons, 9.5:1 compression. 8.5 is was too low.
    Pauter Rods
    moroso oil pan
    itr oil pump
    thats about 3-4k
    Head:
    portflow or RLZ valve springs, retainers, MILD port work
    crower 402T cams, or just stock gsr cams
    JG intake manifold, or other high volume plenum.
    ~1500-2500
    Tranny/driveline:
    GSR, Quaiffe LSD
    gator stage 2 axles
    act clutch/pp
    if you already have the gsr tranny, thats like 2k in parts.
    turbo setup:
    Full-race.com stage3 w/ t3/t67
    4k
    fuel management:
    walbro 255
    uberdata or better EMS
    GEmfg fuel rail
    fast-turbo.com filter-rail SS line
    800-1000cc injectors
    1-3k depending on ems
    3" exahust
    gauges, misc electronics, boost control, etc...
    1-2k or even more...
    so yeah, i blew away 10k a long time ago.
    good luck. :p
