need tranny help
Discussion in 'General Tech and Maintenance' started by phippsc, May 1, 2009.
  1. phippsc
    phippsc New Member
    east of indianapolis IN.
    i am swaping d series motors and i need help getting the tranny off the old motor. does it just pull apart or what cuz i cant get it off. i need help fast. i have 18 days of school left and need it done before that. help!!!!
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just take all the bolts out and then it just pulls off
  3. phippsc
    phippsc New Member
    well ive got them all out and it wont come....is the seal just that tight?
  4. AHHVTEC
    Alabama
    keep in mine there are bolts on both sides of the trans holding it on, and naa it should come right off
  5. phippsc
    phippsc New Member
    yea i got them all...me and 3 other people have looked it over multiple times and we cant see any more to take off. ill have to just tug on it i guess
  6. jlicrx
    jlicrx Senior Member
    Colorado Springs
    did you take the starter off? one of the starter bolts goes thru the transmission into the back of the block
  7. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    yep...take out that starter and if it still doesnt come off then you forgot a bolt maybe on the bottom of the trans next to the shift linkage...happened to me before. that one lil 17mm was holdin er on
  8. doeboy208
    doeboy208 New Member
    there is a snap ring twist and pull the tans. i had the same problem with mine its a bitch to take off. just remember to twist and pull.
  9. phippsc
    phippsc New Member
    alright thanks guys. lots of help
  10. doeboy208
    you could put a crow bar inbetween the motor and trans and get it started then as i said. now if you not going use either of the parts just pry it off.
  11. phippsc
    phippsc New Member
    yea i plan to reuse the tranny with my other motor so i dont wanna mess it up. i have it at school and cant do anything with it until monday but i will try it first thing monday morning and let you guys know how it goes. u guys are great!!
  12. phippsc
    phippsc New Member
    got the tranny off. thanks guys
