Need wiring diagram for d16y7
Discussion in 'Civic and del Sol - EG and EK' started by t rick, May 29, 2007.
  1. t rick
    t rick New Member
    Like the title says
  2. custompainter
    custompainter drive it like U stole it
    central CT
    ecu or motor ?
  3. t rick
    t rick New Member
    Well from the motor to the ecu and fuse box.I did i wire tuck and i need to check because it won' start now it will just turn over. No spark
  4. custompainter
    central CT
    is your car obd2a or obd2b
  5. t rick
    t rick New Member
  6. custompainter
    central CT
    FFS TechNet Home [​IMG][​IMG] FFAQ [​IMG] Downloads [​IMG][​IMG][​IMG]OBD2a Civic & Integra ECU Pin SchematicsAuthor: Katman / Created: Jan. 05 / Last Updated: Jan. 06
    SYNOPSIS
    This article exploits a combination of ECU pin locations and wire colors for all M/T '96-98 Civic and '96-99 Integra VTEC and NON-VTEC vehicles.
    OBD2A PLUG CONFIGURATION
    Below is an example that shows the onboard (female) connector configuration for an OBD2a ECU.
    Take note of plugs: A, C, and D.
    The blank connector (B) is only used with civic/integra vehicles equipped with A/T.
    ADDITIONAL INFORMATION
    These pin-out locations were cross-referenced with OBD2a Civic & Integra Helm's service manuals.
    The information in this article applies to:
    • All US OBD2a (96-98) M/T civic ecu's
    • All US OBD2a (96-99) M/T integra ecu's
    • All JDM OBD2a M/T civic ecu's
    • All JDM OBD2a M/T Integra ecu's
    Contact Katman
