New and New to the Engine side of life
Discussion in 'Engine Building' started by BiRdMaN, Jul 9, 2008.
  1. BiRdMaN
    BiRdMaN BirDMaN
    Currently Iraq....
    Gotta Civic Ex. Saved it from a retard who actually molested the CF hood with Paint. Got the Car and now I want to Give her the TLC she deserves. Im a shady tree body repair kinda guy so engines are my weak side. Can anyone tell me where I should start? I thought about ripping the D16z6 out and find a k20 or h22a to put in. as you can see i like power but im on a budget? can I build a fast d16? I want like 300-400hp
  2. BrutalB83
    Rochester Hills, MI
    What is your budget?
  3. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    i wouldnt shoot for high numbers like that with stock internals, but i think it can be done if you build it from bottom up.
  4. HelixB18C1
    HelixB18C1 Member
    Dallas Tx
    b18c1 gigity gigity alright.
  5. Slow&Delirious
    Boonville NC
    yeah, the stock internals for B series engines are much better & stronger than those in D engines. If you have the money, i would recomend a swap but if you are trying to build it up i would stay with the D series because it is cheaper to replace if u blow it up
  6. HelixB18C1
    HelixB18C1 Member
    Dallas Tx
  7. t3t4delsol
    t3t4delsol New Member
    York, Pa
    300hp to 400hp isnt that hard on a d16, Ive seen d16 with mid 600hp, Just fully build the D unless you have 5 grand for a swap and another 2 maybe 3 grand for a decent turbo setup. Just tear the motor down and do a complete rebuild, vitara pistons, tuner toy rods, then atleast a mild port and 5 angle valve job on the head, stage 3 clutch, then slap a t3/t4 turbo and your at your numbers, for about $3500 total. less if you can kind some good prices on parts
  8. Slow&Delirious
    Boonville NC
    & an upgraded ECU, otherwise it would be dead in 6 months
  9. t3t4delsol
    York, Pa
    wow since you have no clue wtf you talking about dont post anymore just learn.
    He has a 95 which still makes him obd1, there is no upgrade to the ecu that he needs to do. thats done by a tuner who knows what hes doing. they will pull your ecu out and put a new burnable chip in it. Then tune the car so the fuel and timing maps are up to par with the new amount of power your putting out with the motor.
    I didn't go into detail with a turbo set up but if you decide to go that route you are going to need
    turbo, turbo manifold, down pipe, high flow cat, cat back exhaust, wastegate, bov, boost controller, intercooler, intercooler piping, intercooler piping clamps, oil feed and return lines for the turbo, larger injectors around 550cc or 660 cc, vacuum lines, misc t fittings, boost gauge, The stage 3 clutch like i mentioned above.
    How you car runs afterwards depends on how competently you rebuild the motor, and how good of a job your tuner does tuning the car.
    btw I have a t3/t4 5bolt stainless steel 3" downpipe with flex pipe for sale, pm if interested
  10. Slow&Delirious
    Boonville NC
    wow, touchy touchy
    anytime you turbo a car, its a good idea to get it tuned to prevent engine damage, sorry if i didnt word that correctly
  11. t3t4delsol
    York, Pa
    Its mandatory, your car will not even start with larger injectors in if you are still running the stock fuel and timing bins
    Btw, sry I didn't mean to be a dick, rough day I quit smoking yesterday so I'm really edgy
  12. Slow&Delirious
    Boonville NC
    its ok man, dont worry about it.
    we are both just trying to help
  13. SLOWdelawareEG
    SLOWdelawareEG my cars go fast
    hilton head island, sc
    the only reasonable response in this thread. and the answer is??:confused: the rest of you need to do some reading:( (not you t3t4delsol). do it here. do it soon. please......
  14. Bkkfarang
    Bkkfarang New Member
    Bangkok and Shenzhen
    t3t4 you are pretty much right but a chipped ecu is still and upgrade
    yes you can build a 300 to 400 hp d series but it won't be streetable really, 250hp is generally accepted as the limit to a stock d series that will last any amount of time .( yes people have gone above that on all stock motors with a greatly shortened motor life ) do you really want or need a 400hp street civic ? plan ahead , research ,over build it slightly , tune it to a lower power level learn to drive it then tune it higher later . a 400 hp front wheel drive can be a real handful to drive
  15. Matts96HB
    Matts96HB . Moderator VIP
    Honestly, if you are on that tight of a budget, stick with the D16. Build and boost it. With the right parts and a good tune, 400 whp is easily had. It has been done.
