new need help
Discussion in 'Accord' started by 92hndacc, Mar 27, 2011.
  1. 92hndacc
    92hndacc New Member
    i resently purchsed a 92 accord with a stock f22a n i want to go dohc what do i need to do can i just swap the head or do i need to swap the whole eng:cool:
  2. 95h22Accord
    95h22Accord New Member
    What are u lookin to spend?
  3. 92hndacc
    92hndacc New Member
    1500 but i wanted to know if i can do anything with f22a block n just swap the head. i still need pain n a lowering kit n suspension
  4. BrutalB83
    Rochester Hills, MI
    Yes, you can do a head swap. An H23 or a dual-cam F22B head should be pretty much a bolt-on affair. H22 is doable, but is a tiny bit more complicated. For $1,500 though you could probably find an entire H22...
  5. 92hndacc
    92hndacc New Member
    would i use the stock h23 or f22b tm blt
  6. MurderedCD5
    MurderedCD5 New Member
    first of all there are no duel cam F22Bs F22Cs yes but that is out of the S2ks. the H22 and H23 are the same head. if you want a good swap, then drop in a H22 or H23 engine. It will be easier and more reliable. and $1500 is enough if you shop around.
  7. BrutalB83
    Rochester Hills, MI
    Sorry, but pretty much everything you just said is straight up WRONG. Next time, research before you post...
    EDIT: I was on my phone when I responded before, so I'll take the time to elaborate a bit now.
    The H22 and H23 heads are NOT the same. The H23 heads are non-VTEC (for the most part). There is a rare JDM VTEC H23 engine that's pretty similar to the H22, but most often when you're talking about an H23, you're referring to the 160 horsepower non-VTEC dual cam engines that came in the 92-96 Prelude Si models here in the United States.
    And yes, there IS a dual-cam F22. It's a JDM motor and it's very similar to the USDM H23 (dual-cam, non-VTEC, about 160 horses). Look it up.
    Like I said, don't just assume you know things. Next time, look in to it and see if you're right before you answer...
